  • 1.  Text boxes
    Posted 12-27-2011 16:59
    There is any way I can set a fixed width to a text object so the inserted text will be wrapped and will flow on height without altering font size and dimensions?
  • 2.  RE: Text boxes
    Posted 12-30-2011 10:33
    Yes, by script editor...
    If needed, I can provide it to you...
  • 3.  RE: Text boxes
    Posted 01-23-2012 17:34
    Could you send that script to me as well? Thanks.
  • 4.  RE: Text boxes
    Posted 01-23-2012 19:09
    Unfortunately this is, at the moment, only possible when using scripting or the API.
    I've send an email to the lead-developper of XPression a few weeks back requesting the option to do this through XPression, i.e. without using scripting/API, so I have faith it will be added in the future (just like many other extensions I asked for in the past).
  • 5.  RE: Text boxes
    Posted 01-24-2012 07:51
    In settext of you're textobject :
    Dim newtext as string
    Dim list As Array
    Dim new_decoupage as array
    Dim decoupage as string
    Dim newtext1 as string
    Dim x as string
    Dim maxlinelen as integer
    Dim line as string
    maxlinelen = 20
    decoupage = text.Replace("|", Chr(10))
    new_decoupage = Split(decoupage, Chr(10), -1, 1)
    newtext1 = ""
    For Each newtext In new_decoupage
    list = Split(newtext, " ", -1, 1)
    line = ""
    For Each x In list
    If (Len(line) + Len(x)) > maxlinelen Then
    newtext1 = newtext1 & line & Chr(10)
    line = x & " "
    Else
    line = line & x & " "
    End If
    Next
    Next
    text = newtext1
    Replace the maxlinelen by the max number of char you want by line. If you need to make a line return by your owns, in the text, put a | character. (ie. "This is a very|long text that I need to wordwrap !")
  • 6.  RE: Text boxes
    Posted 01-24-2012 08:55
    The disadvantage of the method described above is that it counts characters while the "w" is wider then the "i". Therefor the warp won't occur at the same position in each line and the wider the line is (counted in characters), the bigger the difference can be.
    Better is when you use the BoundingBox of the text and compare it to an actual pixel count, but I'm not sure this will work in scripting, It does however in the API and I've been using this for years now.
  • 7.  RE: Text boxes
    Posted 01-24-2012 15:11
    This script will do it using the bounding box. It works in the OnSetText() event of a text object; but you must put the scene online from the Sequencer, otherwise OnSetText() doesn't get called.
    Dim maxWidth As Double
    Dim newText As String
    Dim line As String
    Dim strWord As String
    Dim list As Array
    maxWidth = 400 'maxWidth = Self.AutoSqueezeWidth
    If Self.GetTextWidthS(Text) > maxWidth Then
    list = Split(Text, " ", -1, 1)
    newText = ""
    line = ""
    For Each strWord In list
    If (Self.GetTextWidthS(line & strWord) > maxWidth) Then
    newText = newText & line & vbCrLf
    line = strWord & " "
    Else
    line = line & strWord & " "
    End If
    Next
    Text = newText
    End If
