OK. I will try to use the ASCII Datalinq Source to get data from the Bodet.
Your support told that one other customer had asked the FIBA API previously, but it was determined they needed to build a application that takes the feed and writes it to a JSON file. So I desided to do similar and wrote PHP script, that will read FIBA API and write all read JSON messages to several different JSON files depending on message type, so I can use those files then in Datalinq.
It would be great if the future version of Datalinq could have some kind of "RSS / HTTP Datalinq Source" and "XML/JSON TCP Datalinq" combination source type, i.e. it would be like that HTTP version, but it would also allow use with constantly open connections, i.e. even if the other end does not close the TCP connection,
but sends new JSON messages over it all the time. In that case, it would probably already be compatible with the FIBA API. Now Datalinq does not work with FIBA API.
Br. Juha
Juha Koivisto
Sent: 07-28-2022 11:17
Subject: Scoreboard Bodet & datalinq
Hello - XPression development work for Bodet scoreboard support has not yet been scheduled. I can't provide a timeline for this development at this time.
I can't find any information about a FIBA Broadcast Feed in our feature requests list or support inquiries. I don't believe we've been asked about this data source before.
Sent: 07-09-2022 14:08
It has been 7 years since this discussion, so is there now an integration between Bodet BT6000 and Datalinq & XPression/Tessera or has someone used it with the ASCII Datalinq source?
I am asking, because a FIBA Basketball World Cup match will be played next month here in Tampere at Nokia Arena and the Bodet BT6000 will be used as the game clock. This will be the first basketball game at Nokia Arena.
At the same time I would like to ask if anyone has implemented the integration between FIBA's Broadcast Feed (TV feed) or FIBA's Live Stream API Service and Datalinq & XPression/Tessera?
Juha Koivisto
Sent: 08-01-2015 13:16
Hello Espie & Garner,
I've also received the question by a client to develop some basketball-software to generate graphics which is integrated with the Bodet and Nownet-protocols.
I've contacted Bodet but haven't had any response yet on my question about a possible api or documentation of the protocol.
So if you could forward that protocol information to me, that would be very helpful to me.
Depending on when you need this I might be able to help you out as well?
Best regards,
Kenneth
