Hello Everyone!
Recently we have been experiencing some crashing of Xpression during some of our shows. We see that certain images cause a larger spike in memory usage than others while being played out of Xpression. Comparing the images properties side by side, we were not able to see much differences. We did see however the pictures that were causing some issues were missing some meta data that others had.
For instance, pictures that are working ok have this data.
Color Model: RGB
Depth: 8
DPI Height: 72
DPI Width: 72
Orientation: 1 (Normal)
Pixel Height: 920
Pixel Width: 1,650
Profile Name: sRGB IEC61966-2.1
Date Time: Oct 13, 2014 11:04:04 AM
Resolution Unit: inches
Software: Adobe Photoshop CC (Macintosh)
X Resolution: 72
Y Resolution: 72
While the images that appear to be less stable have this data
Color Model: RGB
Depth: 8
DPI Height: 72
DPI Width: 72
Pixel Height: 920
Pixel Width: 1,650
It seems that the problematic images are missing some of the meta data. They do not have a color profile associated with them and they do not have an orientation asset.
Would this be causing something in Xpression to malfunction and crash?
Let me know if I can give you some more info. Any and all help would be greatly appreciated.
