Yes, the latest beta build of XPression should resolve this issue.
Contact Tech Support and they can assist you with trying it.
The reason it appear black and white is that the output was a component Y/Cr/Cb signal which you were probably expecting to be a composite, so the Y channel fed into a composite monitor would appear as Black/White.
