  • 1.  Datalinq connecting to Click Effects and MLBAM
    Posted 10-13-2016 15:43
    Is there a way to connect datalinq to click effects and the MLBAM plug in?
    We are using Xpression Designer.
  • 2.  RE: Datalinq connecting to Click Effects and MLBAM
    Posted 10-17-2016 19:48
    I've not heard of anyone making this connection before.
    Does ClickEffect/MLBAM output the data in some way? XML, SQL, Serial String, etc...
  • 3.  RE: Datalinq connecting to Click Effects and MLBAM
    Posted 10-17-2016 21:02
    The Click Effects MLBAM plug-in simply pulls an XML file from MLBAM's servers and parses it. If you've got a contact that could give you the raw web address of the XML it's pulling from, you can accomplish the same result with DataLinq.
