  • 1.  Windows 8 and XPression 5.0 Design
    Posted 07-25-2013 19:44
    Anyone else using XPression Design on Windows 8 Professional? I am experiencing a problem on some of the pull-downs from the menubar not displaying properly. It appears like something is blocking the menu, so I can't read the text in the menus. However, there is nothing obscuring the menus in the application, no other applications running, and nothing on the "Start window" in those same spots.
    Not experiencing this on Windows 7 Professional...
  • 2.  RE: Windows 8 and XPression 5.0 Design
    Posted 07-25-2013 20:15
    Hello Patrick,
    This is a known issue with XPression on Windows 8. Unfortunately XPression has not undergone product verification for Windows 8 and and Ross does not at this time support XPression running on Windows 8.
    XPression hardware and software specifications
    My only suggestions would be to try changing the Windows default text size, and display options in the control panel.
  • 3.  RE: Windows 8 and XPression 5.0 Design
    Posted 07-26-2013 03:18
    Thanks for the info. Bought a new laptop last week, and the only option in the store was Windows 8. Maybe I will try the downgrade... For now, I will use the workaround like you suggested.
