  • 1.  Inception & Xpression Templates
    Posted 10-07-2016 19:53
    We just got a demo setup for Inception.
    I have a playlist of tweets in Inception and I am wondering how to actually play it out in Xpression through my templates.
    I have the datalinq server set up with a rss feed and all the info is pulling correctly.
    Once I go to my crawl and link my text objects to the correct data source, how do I make that automatically play the next tweet ?
    Do I need to have multiple templates? Right now, it's only pulling the first tweet even if I use the in the row field.
    I would really appreciate the help.
    Thank you!
  • 2.  RE: Inception & Xpression Templates
    Posted 10-12-2016 18:33
    You would have a scenegroup with multiple child scenes and each child scene would increment field being read from the RSS Inception feed.
    Text Object Datalinq Column in Child Scene 1 would be:
    channel\item\description\#CDATA
    Text Object Datalinq Column in Child Scene 2 would be:
    You should not have anything in the Datalinq Properties Row field when using RSS feeds (it's XML).
