  • 1.  xpression 5_video clips playing at twice the speed
    Posted 08-28-2013 20:03
    I'm using Xpression 5.0. When I import video clips (after ecoding with Xpression Video Coder) into Xpression, they playback at twice the speed. So, a 15 sec clip plays back at just over 7 sec. I check the settings in Video Coder and tried different frame rates and they all still playback at 7sec. Can someone shed some light on this?
  • 2.  RE: xpression 5_video clips playing at twice the speed
    Posted 08-28-2013 20:04
    Were the clips originally created in Final Cut Pro?
  • 3.  RE: xpression 5_video clips playing at twice the speed
    Posted 08-28-2013 20:44
    Not sure. They came from an outside source. If they were, whats the issue?
  • 4.  RE: xpression 5_video clips playing at twice the speed
    Posted 08-28-2013 21:08
    Final Cut Pro and Quicktime have bugs that store the incorrect framerate of the clip in the metadata. These clips will not play back correctly in XPression. To avoid this, it's very important to ensure that clips exported from Final Cut Pro are not using one of the presets, but are exported with the settings configured manually.
    I don't know if this is the issue, but is problem we encounter semi regularly.
  • 5.  RE: xpression 5_video clips playing at twice the speed
    Posted 08-28-2013 21:28
    Cool, thanks.
    Just realized the video was created at 29.978. I had to re-export out of AE at 59.97 and run through Video Coder at that same rate. Now Xpression is running the video correctly.
