  • 1.  Transition Logic - Clearing graphic
    Posted 10-09-2015 16:38
    I am trying to incorporate transition logic in most our graphics.
    Is there a way to make the graphic stop running in the background?
    I have the transitions set up and everything is working fine but one of this graphics has audio in it and I can still hear it playing even though I transitioned to the new graphic. Is there a way to make it stop?
    thank you in advance!
  • 2.  RE: Transition Logic - Clearing graphic
    Posted 10-09-2015 17:00
    If the graphic is no longer online then there isn't any way you should be still hearing it.
    Does the old graphic still say "online" in the sequencer? If so, then you might just have put a new graphic on a layer overtop of the old one?
  • 3.  RE: Transition Logic - Clearing graphic
    Posted 10-09-2015 18:49
    Hi Brian,
    It says transition in. Is it perhaps that the animation is 30 sec long?
  • 4.  RE: Transition Logic - Clearing graphic
    Posted 10-13-2015 13:34
    Normally the "effect in" that you set in transition logic should just be a scene director that handles the transition of the scene online (i.e. usually it's quite short). (both the old and new scene will be online during the transition). Longer animations would normally be done on the main scene director. So, the new scene should only be in the transition in for a very short period of time.
    In your situation, on the scene with the long transition in, you could Tick the checkbox labelled "Wait for Out Effect". This will make sure the old scene plays offline completely before it starts to transition the new scene online. I think this would solve your problem.
