  • 1.  APITexture
    Posted 06-23-2015 13:35
    Hi all !
    I have to draw a curve (that is ok). And I have to fill the zone between my curve and a line at the middle.
    Is there a way to do that ?
    Thank you.
  • 2.  RE: APITexture
    Posted 06-25-2015 08:00
    Here an example of what I need to achieve
  • 3.  RE: APITexture
    Posted 06-25-2015 14:07
    Can you use the FillPolygon function and draw the curve using a large number of points?
  • 4.  RE: APITexture
    Posted 06-26-2015 21:24
    Unfortunatly, no i can't.
    Number of points are random, so this method is not for me... :(
  • 5.  RE: APITexture
    Posted 06-26-2015 21:29
    Does the DrawClosedCurve method do what you need (except for the fact that it is not Filled in)? We can add a FillClosedCurve function to the API if that helps..
  • 6.  RE: APITexture
    Posted 06-26-2015 21:32
    I have to test how this method is acting, I'll tell you asap.
    Thank you !
  • 7.  RE: APITexture
    Posted 07-03-2015 04:35
    Thank you for the api update ! :)
