  • 1.  Reflection Map
    Posted 05-31-2012 20:17
    are there any plans for a video as a reflection map?
  • 2.  RE: Reflection Map
    Posted 05-31-2012 20:19
    There is a trick to using any shader as a reflective map. In the texture coordinates of the shader, you can select "spherical reflection", which will give you the result you are looking for I believe.
  • 3.  RE: Reflection Map
    Posted 05-31-2012 20:23
    Sounds not to bad to me. I will give it a try tomorrow. Thanks
  • 4.  RE: Reflection Map
    Posted 06-01-2012 15:06
    @JBMorrison:
    Thanks for your tip.
