  • 1.  Export from After Effects
    Posted 02-17-2014 13:25
    We have many animated backgrounds in After Effects that we need to use in Xpression. I'm using the Xpression codec 5.15. I dont see the alpha channel. What do we need to do?
  • 2.  RE: Export from After Effects
    Posted 02-18-2014 14:46
    I always use "Lossless with Alpha" as the base setting, then in the format options, choose the XPression codec. Works great for me.
  • 3.  RE: Export from After Effects
    Posted 02-18-2014 18:44
    Worked Great thanks a million!
