We use the Xpressions plug in with ENPS and most things work fine that way, but I noticed that if you try to insert a tab in a text field (using control + Tab otherwise it just takes you to the next field) things get a little messed up. First of all the tab fields in my preview don't line up like they do when using Designer or the Sequencer. Random tabs (Not all of them) are off by a little bit. Another problem is that after adding the template to the story it doesn't save the tabs. So if you input "blah(insert tab here)blah" it turns to "blahblah". Xpressions has a lot of cool functions you can do with tabs, but if the plug in doesn't save them it doesn't do you any good. Can anyone shed some light on this? I was hoping there was a setting I could change to allow tabs, but I couldn't find one.
