I've created an event in layout with multiple keyframes, and when I add it to the sequencer, a few objects are off - larger and not in the same position. When I look at it in the scene director or in layout, it looks fine. I've tried re-adding the event to the sequence, duplicating the event and adding THAT to the sequence, and I've gone back and checked every keyframe... still no luck. Any ideas??
