  • 1.  Auto fade transition from scene to scene
    Posted 03-01-2016 19:10
    Hey all,
    Would anyone be able to tell me, if it is possible, to fade between scenes with a transition? I know how to set it in the transition tab in sequence to operate how I imagine I would need it to. However I think it would be better, faster, easier to operate if I was able to set up a script or something of that nature in each scene.
    I have 3 scenes I need to transition between one after the next and I need two of those to fade off once there are no more animation controllers left to play through.
    Apologies if my explanation is not adequate, can explain further if it's not entirely clear.
  • 2.  RE: Auto fade transition from scene to scene
    Posted 03-24-2016 18:23
    I think you are talking about the Take Item option called Default Transition. In the scene you want to assign the transition, click on first object. In the Object Inspector, the fourth tab is called Take Item. Look in there and you will find the way to assign default transition for IN and OUT. Then it will always come up for that scene.
