it is not possible to update the position of an animation controller or a scenedirector clip with the
xpAnimController.Position
or
xpSceneDirectorClip.Position
command from within a script.
Please could you fix this as soon as possible as we have to use this commands to control our recent show tomorrow.
Please could you also implement a new command to delete a scenedirector clip (e.g. it is not possible to delete a material clip from within a script). We could not find such a command in the SDK help (whereas the delitition of an animation controller is possible with the xpAnimController.delete command)
With high hopes ;-) and best regards
