The fast recall input timeout will control that.. If the timeout is enabled, then after about a second it will assume you are done typing the number and should jump to the item.
Otherwise, if you don't want the timeout enabled, you can hit the * key in the numpad to jump you to the item without actually taking it on air yet.
