Video files playing slowly
  • 1.  Video files playing slowly
    Posted 10-30-2015 20:27
    We have a couple short video files (Xpression Codec) that we've been using in our Xpression project for about a year now. An opener, and a bumper. On our last show though, these files were playing back very slowly, and the perf meter would jump up to about 140% while playing.
    I had this issue once about a month back, but a reboot fixed it. But that's not the case anymore.
    Any idea what could be causing this?
  • 2.  RE: Video files playing slowly
    Posted 10-30-2015 22:17
    I would double check the frame rate of the video clips and the project to make sure they match.
  • 3.  RE: Video files playing slowly
    Posted 11-01-2015 14:26
    Hi Brian,
    Just confirming, the project and the video clips are 29.97
  • 4.  RE: Video files playing slowly
    Posted 11-02-2015 15:28
    Another bit of info: The issue only exists when playing through the hardware output. When playing through the virtual monitor, they play fine.
  • 5.  RE: Video files playing slowly
    Posted 11-02-2015 15:30
    Can you send a link to the project?
  • 6.  RE: Video files playing slowly
    Posted 11-02-2015 21:07
    Sent via PM, thanks!
  • 7.  RE: Video files playing slowly
    Posted 11-02-2015 21:40
    I played all the videos out both a Virtual FB and out a hardware matrox output and they all played at the same speed.
    If the perf jumped to 140, was something else online on a different layer using up resources maybe?
    Can you still reproduce the issue?
  • 8.  RE: Video files playing slowly
    Posted 11-02-2015 22:51
    Hi Brian,
    Yes I am still able to reproduce the issue. Nothing else is online. As I mentioned, we've been using these clips for the better part of a year now with no issues, so I'm thinking maybe hardware issue?
  • 9.  RE: Video files playing slowly
    Posted 11-03-2015 01:04
    Maybe.. I'd contact tech support and maybe they can log into your machine to observe the issue..
  • 10.  RE: Video files playing slowly
    Posted 11-04-2015 22:19
    If anyone else has this problem, our tech support guy went into the hardware setup, and removed the video card from the outputs, then re-added it again. So far so good! :)
  • 11.  RE: Video files playing slowly
    Posted 11-05-2015 16:37
    I have a similar issue here. Video (nba player SOT) is playing fine video wise however audio is out of sync.
  • 12.  RE: Video files playing slowly
    Posted 11-05-2015 16:46
    Malcolm,
    Audio being out of sync is often caused by rendering the file to XPression codec from within another application and it does not have the Audio Interleaving value set to 1 frame. If you download the free open source MediaInfo and examine the file, check the "Interleave Duration" value in the audio section to see if it is set to "1 frame".
  • 13.  RE: Video files playing slowly
    Posted 11-05-2015 18:54
    I made a quick fix by exporting the audio in .wav and just applied it to an audio track. I can then slip it into sync and also adjust output levels.
