  • 1.  Default take item - Layer
    Posted 12-05-2014 16:19
    I have a scene that is set up to default to Framebuffer 2, Layer -1. It works fine in the sequencer offline, but ENPS seems to override the layer setting and sets it to the the channel default (which apparently is set to 0). The Framebuffer setting carries through but not the layer. Any thoughts on how I can force the layer setting?
  • 2.  RE: Default take item - Layer
    Posted 12-05-2014 16:22
    Adam check the the layer options setting in your MOS gateway.
    You will want to make sure it is set to "default for template". You will find this setting in the "client plugins" menu of the gateway.
  • 3.  RE: Default take item - Layer
    Posted 12-05-2014 16:36
    Thanks! That worked.
