  • 1.  Text Format
    Posted 08-30-2013 13:33
    Is there some way to set a text box so that no matter what you type in it, it will appear in all caps?
  • 2.  RE: Text Format
    Posted 08-30-2013 20:18
    You can assign a font to the textbox that has the "Sml Caps" property set to 100%.
    Or you can use an OnSetText script that would convert everything to uppercase.
    text = UCase(text)
