  • 1.  Published but not seen in ENPS
    Posted 07-06-2016 13:22
    I published a project and the files show up in one of the preview windows in ENPS , but when you double click to start working on it, it's hung up on screen and says " Loading Project" over black. Is this a setting perhaps that is wrong? Thanks for any help. The MOS will not work in ENPS as well, and loading the rundown is all in RED in Studio.
  • 2.  RE: Published but not seen in ENPS
    Posted 07-06-2016 13:38
    Do you have project server? It sounds like it isn't running or the preview and playout engines can't connect to it (or aren't configured to).
  • 3.  RE: Published but not seen in ENPS
    Posted 07-06-2016 14:59
    Yes, we have one and for the other graphics previously made, it's working fine. I started this project yesterday and nothing in it will work, but all other graphics on the other projects are working.
  • 4.  RE: Published but not seen in ENPS
    Posted 07-06-2016 15:03
    So this is a new project that doesn't work?
    Did you upload it to the project server? And if so, did you create a new show for it? If you created a show for it, did you create a category and style as well? (if you other shows on the project server don't use categories and styles you won't make one for the new one either).
  • 5.  RE: Published but not seen in ENPS
    Posted 07-06-2016 16:50
    Yes, it's a new project that doesn't work.
  • 6.  RE: Published but not seen in ENPS
    Posted 07-11-2016 16:57
    Do you see the project in the project server manager?
    Also, if this is impacting your on-air product please reach out to techsupport@rossvideo.com for immediate assistance.
