  • 1.  Datalinq and time to put on air
    Posted 11-17-2015 10:49
    I've got a scene with some text object filled by datalinq.
    When I put it online thru sequencer, Xpression take 1 to 3 second to prepare it...
    Do you have any idea ?
  • 2.  RE: Datalinq and time to put on air
    Posted 11-17-2015 12:11
    What type of datasource is the scene using? Excel?
  • 3.  RE: Datalinq and time to put on air
    Posted 11-17-2015 12:13
    An Excel, but with ADODB Connection
  • 4.  RE: Datalinq and time to put on air
    Posted 11-17-2015 12:22
    In the advanced settings for the ADODB connection do you have record limiting set to TOP clause?
    (Edit ADODB > Advanced > Record Limiting)
  • 5.  RE: Datalinq and time to put on air
    Posted 11-17-2015 12:24
    I have "not supported" right now, but Top is avalaible
  • 6.  RE: Datalinq and time to put on air
    Posted 11-17-2015 12:25
    Set it to use top clause. That should help a lot.
  • 7.  RE: Datalinq and time to put on air
    Thank you, I'll try it !
  • 8.  RE: Datalinq and time to put on air
    Posted 11-17-2015 18:01
    Also make sure the Workbook is set to Shared in Excel.. Failing to set it to shared can make it very slow.
