  • 1.  Scripting Quad Height and/or Width
    Posted 09-02-2013 03:14
    Good evening,
    I see there are height and width properties for quads (and other objects). What is the syntax in a script to control these?
    Brian
  • 2.  RE: Scripting Quad Height and/or Width
    Posted 09-02-2013 17:42
    Hey Brian,
    This is pretty straight forward just make sure you dimension your objects as specific object types.
    so if you wanted to affect the height of your quad it would be:
    Dim quad as xpQuadObject
    Then retrieve it
    Self/Scene GetObjectByName("name", quad)
    quad.height = 000
    same for width and depth
    Andrew
