We use a very complicated lower third, that with script works like this:
There are three lines of text. We'll call them Top, Main, and Bottom. If there is text in the Main and Bottom lines, groups A and C are visible. If there is text in the Main but not Bottom lines, group B is visible. If there is no text in Main or Bottom, but in Top, the top's group PosY changes.
Altogether, the scene works like this:
Top Line
Main Line
Bottom Line
OR
Top Line
Main Line
(hidden bottom line, as Main Line is now larger)
OR
(hidden Main Line)
(hidden Bottom Line)
Top Line (in a lower PosY, the same as the "normal" Bottom Line)
Is this even remotely possible with Visual Logic? I have it working in script, but my boss would like me to get as much moved to VL instead of script as possible.
