Wondering if anyone has run into this issue.
Almost every time we re-publish our projects, one or two of the graphics in that project changes without us editing/working on it. What happens is that the published objects in the template links shift up. For example: If a quad meant to have a picture is published with the ability to adjust texture position and texture scale, after publishing the check marks move up one.. to visibility and texture position.
Right now, we just fix it after someone tells us that they can't move/scale something and we just go ahead and fix the check marks and republish.
Could this be some sort of a bug? Any ideas?
Appreciate the help!
