  • 1.  How would I add audio to timer widget?
    Posted 08-01-2013 05:54
    How would I add a sound effect to timer widget so you'd hear clock ticking while it counts down and a buzzer goes off when it reaches 00:00? Is this even possible?
    I added the audio track onto the scene director but the audio starts when I take the item online and not when I start the timer in the widget. Is there a way to start the audio when I start the timer or trigger the buzzer when the clock reaches a certain timeframe?
    Thank you in advance.
  • 2.  RE: How would I add audio to timer widget?
    Posted 08-19-2013 08:52
    In this case I use the clocktimerwidgetevents.
    At defined values I trigger a audio-sampler via midi.
    It is also possible to set online and play other scenes containing the audio files at this values.
  • 3.  RE: How would I add audio to timer widget?
    Posted 08-22-2013 23:38
    spectro, Thank you. I'll see if I can get it to work and report back.
