  • 1.  Sequencer Issues
    Posted 11-04-2013 03:01
    Hi, is there any way to automate colour coding of slugs for the sequencer?
    The graphics dept at the moment has to manually change each scene colour, but we would prefer if there was an option in inews.
    Would this require scripting? I am not sure where to begin.
    Cheers
    Tai
  • 2.  RE: Sequencer Issues
    Posted 11-04-2013 03:20
    I don't believe you can set a default color Tai. The group objects can be selected and from there an entire group can be colored, but you are probably wanting lower thirds to be one thing, full screens another. Correct?
    If so, the process would be a bit tedious. Group everything, color the groups, and then distribute within the sequence, but like I said, that's a bit of work.
    Also, you posted the same topic several times so I deleted those other posts.
