CBN, I believe the font size is fixed and based on the video format. If you go File->New, what is the default video format that each of your two boxes defaults to? My guess is that one of the two is set differently.
Mike,
There should be release notes for 6.5. I am not sure why they are not on the XPression website but I'll follow up. 6.5 has been officially released. If you contact Tech Support they can send you the release notes.
