visual logic: using number value to trigger an animation
  • 1.  visual logic: using number value to trigger an animation
    Posted 04-03-2015 19:58
    I have a scoreboard that displays quarters. As we go into overtime the value of the quarter is 5. I want to use this value to trigger a scene director that will cause a cube to rotate 90 degrees. What is the best way to do this?
  • 2.  RE: visual logic: using number value to trigger an animation
    Posted 05-04-2015 15:33
    Pretty simple fix using visual logic. Consider this post solved.
