Hi Chris,
If you go to the website of XPression (
http://www.rossvideo.com/graphics-system/xpression/) you should see XPression Downloads somewhere on the right of the screen.
That will take you to a secure environment where you can log in and download the latest versions of XPression.
for this you will need a login which is normally provided to you if you have a maintenance contract with Ross.
Cheers,
Kenneth
