  • 1.  Not able to import materials
    Posted 12-06-2014 22:34
    Not able to import materials to Xpression. When trying to drag over a image to the materials I get the "do not" logo (circle with a line through it). Tried .psd, .jpg, .png. Running Xpression v5.5. Same thing goes for the object inspector in layout mode.
    Appreciate any insight.
  • 2.  RE: Not able to import materials
    Posted 12-06-2014 23:50
    The drag/drop feature for importing materials might not work if your project isn't saved or if you have UAC enabled.
    Control Panel > Administrator Tools > Local Security Policy > Local Policies > Security Options > User Account Control: Run all administrators in Admin Approval Mode" > Disabled
    I believe you can only drag/drop into the viewport and materials manager.
  • 3.  RE: Not able to import materials
    Posted 08-21-2018 16:42
    Hello. I got the same problem with an 5.15 Xpression version. I can drag and drop materials but when I try to import them from the material manager the application shut down.
    I checked the "Control Panel > Administrator Tools > Local Security Policy > Local Policies > Security Options > User Account Control: Run all administrators in Admin Approval Mode" and he's "Disabled"
    This application use to work great and nothing changed in the configuration lately.
    Best regards
    Florent
  • 4.  RE: Not able to import materials
    Posted 08-21-2018 17:05
    Are you importing from a network share/drive or USB or a local disk?
  • 5.  RE: Not able to import materials
    Posted 08-21-2018 17:40
    It's from the local disk. The "image" folder of the project. Xpression sometime cash befor I try to import, just when I clic in the material manager window.....
    I tryed with different projects and I got the same problem. We've got 3 Xpression here I tryed my project on the 2 others computers and everything is ok I can import normaly on those 2 Xpression with the same project.
