Hi all,
Would you recommend that we run a SQL server locally on the XPression Studio PC or should the server be run on a separate machine? What are the best practices or recommendations on where to host the SQL server?
We also have not decided on a flavor of SQL if anyone has any recommendations.
Our table is a couple thousand rows and a few dozen columns large. Only one user (Xpression) will access it at a time.
Thank you for your time,
