  • 1.  Recommended hardware for Dual Channel systems
    Posted 10-05-2016 15:16
    Hi
    I was wondering if you had any recommendations for a Dual Channel system?
    For instance, would I require to separate graphic cards?
    How about the video cards, are the Aja Corvid 44 preferred?
    Thank you :)
  • 2.  RE: Recommended hardware for Dual Channel systems
    Posted 10-06-2016 13:48
    On the XPression website, you'll find this link: http://www.rossvideo.com/pdf/cutsheets/xpression/xpression_specification_sheets.zip
    It includes the recommended hardware. For a dual channel system I would recommend either a Matrox XMIO 5000 output card, or a Corvid88.
    We have not tested with a Corvid44 card (though it's probable it may work).
