Hi Greg,
If you still have your Studio/BlueBox/Deisgner/Developer/Prime installer (.exe) you can run the installer and select to only install the 'XPression Datalinq Server' component.
Otherwise you'll need to reach out to Tech Support (
techsupport@rossvideo.com) and tell them what version and build (ex. 5.7 3064) of XPression Datalinq you need. This version will match your other XPression software.
