  • 1.  Force preview to update visual logic
    Posted 04-26-2016 18:56
    I have a scene set up where visual logic is used to turn layers on and off and change their position. In the sequencer preview window the position (which is based on visual logic) doesn't update properly, but when I take a scene it is displayed correctly.
    Is there a way to force the preview to update the visual logic command without taking a graphic live?
  • 2.  RE: Force preview to update visual logic
    Posted 04-27-2016 14:07
    Preview normally does update the visual logic.. Can you post a screenshot of your visual logic so we can see what might be different that wouldn't run in preview?
  • 3.  RE: Force preview to update visual logic
    Posted 05-12-2021 18:10
    I have this same problem too, frequently...
    Kraig Kirkaldie
  • 4.  RE: Force preview to update visual logic
    Posted 05-12-2021 18:12
    It's usually caused by the order in which you have your tabs. Visual Logic tabs are rendered from left to right so that's always worth bearing in mind when you are creating your logic.
