  • 1.  Starting API without admin rights?
    Posted 12-03-2015 07:39
    When I start Visual Studio and write a program to connect to XPression, I have to start VS as Administrator. And also the exacutable that I create has to be started As Administrator to be able to connect to XPression. Is there another way?
  • 2.  RE: Starting API without admin rights?
    Posted 12-03-2015 07:43
    Under W10 I imagine ?
  • 3.  RE: Starting API without admin rights?
    Posted 12-03-2015 07:59
    W8 in this case
  • 4.  RE: Starting API without admin rights?
    Posted 12-09-2015 14:49
    Under Windows 7 this is possible. You must be logged in as an administrator and disable UAC on the machine.
    From the Local Security Policy you want to make sure your settings look like this:
    https://i.imgur.com/3qXQwqk.png
    I don't know if this works in W8 though.
