  • 1.  XPression - Text and Perspective Cameras
    Posted 08-24-2015 19:25
    Hi all,
    So I am dealing with a lot of text that is zoomed into and zoomed out of with a perspective camera object and unfortunately when zoomed in the text is very pixelated as opposed to being normally rendered once the camera is zoomed out. I must also specify that the zoom is not exactly a zoom, rather it is being moved closer and further away from the subject on the Z-axis. Would a different camera work better in this instance? Any input or suggestions is always appreciated!
    Thanks again,
    Hunter
  • 2.  RE: XPression - Text and Perspective Cameras
    Posted 08-24-2015 19:26
    Set a big font size and scale down texts objects.
  • 3.  RE: XPression - Text and Perspective Cameras
    Posted 08-24-2015 19:30
    Initially I thought that might solve the problem but I'm not sure that's the best way to go about it. I need to be zoomed out and need to be able to animate the camera to zoom into specific points in the scene.
  • 4.  RE: XPression - Text and Perspective Cameras
    Posted 08-24-2015 19:50
    And ? no pb with that... This solve the problem...
  • 5.  RE: XPression - Text and Perspective Cameras
    Posted 08-24-2015 19:51
    Haha it did thank you so much!
