  • 1.  This logo, not that
    Posted 10-12-2015 04:04
    I have some graphics that I've made to select the correct logo for each show by employing the visibility check box. I would like to save the newsroom from themselves and make it so that only one logo can be visible at a time. I know how to link visibility in Visual Logic but for some reason can't make it go the other way.
  • 2.  RE: This logo, not that
    Posted 10-13-2015 14:12
    I haven't ever seen a way to do this in Visual Logic, but I've done it in scripting quite a few times. We have a franchise that has multiple options (AM Edition, Noon Edition, Evening Edition, Weekend Edition, etc), and each has its own unique logo. I published the visibility of all but one (the basic "fnf" logo), then used this script:
    dim fnf as xpBaseObject
    dim fnfam as xpBaseObject
    dim fnfnoon as xpBaseObject
    dim fnfpm as xpBaseObject
    dim fnfwkd as xpBaseObject
    dim fnfspcl as xpBaseObject
    Self.GetObjectByName("FNF Logo", fnf)
    Self.GetObjectByName("FNFAM Logo", fnfam)
    Self.GetObjectByName("FNF Noon Logo", fnfnoon)
    Self.GetObjectByName("FNFPM Logo", fnfpm)
    Self.GetObjectByName("FNF Weekend Logo", fnfwkd)
    Self.GetObjectByName("FNF Special Logo", fnfspcl)
    if fnf.Visible=True then
    fnfam.Visible=False
    fnfnoon.Visible=False
    fnfpm.Visible=False
    fnfwkd.Visible=False
    fnfspcl.Visible=False
    elseif fnfam.Visible=True then
    fnf.Visible=False
    fnfpm.Visible=False
    elseif fnfnoon.Visible=True then
    fnf.Visible=False
    fnfam.Visible=False
    fnfpm.Visible=False
    elseif fnfpm.Visible=True then
    fnf.Visible=False
    fnfam.Visible=False
    elseif fnfwkd.Visible=True then
    fnf.Visible=False
    fnfam.Visible=False
    fnfpm.Visible=False
    elseif fnfspcl.Visible=True then
    fnf.Visible=False
    fnfam.Visible=False
    fnfpm.Visible=False
    fnfwknd.Visible=False
    end if
    It simply goes through every item to see if something is set to visible, then turns the visibility off on every other object. There's a lengthier section following it that displays a warning message if more than one is set visible, as well.
