  • 1.  How to Create A Mask?
    Posted 12-13-2013 17:30
    I've searched through the topics, but not really found a good explanation on how to make a mask. What I have is image on a quad that I want to reveal with an animated mask. I assume I need to use a black/white video for the mask? How and where and what do I apply the animated mask video to? Thanks!
    Also, how do you create a "Layer Object" ?
    Chuck
  • 2.  RE: How to Create A Mask?
    Posted 12-13-2013 21:28
    Hi Chuck,
    You can create a mask by setting a materials layer blending mode to 'Alpha Mask'.
    See this screen image:
    Layer Objects can be created by selecting them from the Object Library. This will add a Layer Objet to the Object Manager of the Scene that is currently selected. You can drag and drop other objects into the layer object, exactly like you would a Group Object. Material Alpha masks applied to objects in a Layer Object will only mask the objects in that Layer Object.
  • 3.  RE: How to Create A Mask?
    Posted 12-13-2013 23:50
    Thanks Garner...
    I'm using XPression Designer V3.21... :-(
    There doesn't seem to be way to add a layer object in my version and I don't have the same options shown in your screen shot for making a mask.
    Any help you can provide in creating a mask with my version? Thanks.
    Chuck
  • 4.  RE: How to Create A Mask?
    Posted 12-16-2013 22:46
    Sorry to bump this topic, but I'm under a short deadline! :-)
    I'm running XPression Designer V3.21. Can someone help me create a mask using my version?
    Chuck
  • 5.  RE: How to Create A Mask?
    Posted 12-16-2013 22:57
    Hi Chuck,
    I believe for v3.21 you'll need to use the following settings for the layers blending properties:
    Blend Operation "“ ADD
    Source Factor "“ ZERO
  • 6.  RE: How to Create A Mask?
    Posted 12-17-2013 00:31
    You can also just rightclick in the material manager and choose New->Mask.
