  • 1.  System Time
    Posted 01-02-2018 19:46
    Since it's that time of year, how can you grab the system time (month, day, year) and display it by using either a script or visual logic?
    thanks!
    Brian
  • 2.  RE: System Time
    Posted 01-02-2018 20:53
    Can you use the clock widget?
  • 3.  RE: System Time
    Posted 01-04-2018 20:34
    I was going to use the system time to derive the year for copyrights. I tried using the vbscript methods but wasn't getting the data. I suppose I could use the clock widget if that's the best method.
