  • 1.  XPression not seeing all installed weights of a font
    Posted 02-03-2018 01:13
    So, I am having an issue wherein XPression is only seeing a single weight (bold) of a font (Boxed) installed on my system with all 16 weights of said font visible in literally every single other program on my machine for which font is a selectable attribute. There are 2 instances of this font available from the XPression selection window, one has (private) appended to the end of it, the other does not, but regardless of which one I select the 'Style' option is grayed out, with Bold as the selected style, and does not allow a change to be made.
    This is a very vexing issue, and seems to be unique to XPression... anyone run across this before, and can tell me how I can fix it?
    - Willie
  • 2.  RE: XPression not seeing all installed weights of a font
    Posted 02-03-2018 13:46
    Can you open a case with Ross Tech Support and send them the font; so we can investigate?
  • 3.  RE: XPression not seeing all installed weights of a font
    Posted 02-06-2018 01:49
    Well, it turns out that I was able to rectify the problem my locating the Fonts folder XPression created in it's project structure, and deleting the instance of the font which had been brought over through some behind-the-scenes process. Once I restarted XPression with that font deleted, I was able to once again access all flavors of it.
  • 4.  RE: XPression not seeing all installed weights of a font
    Posted 12-17-2019 18:33
    I just had this exact same problem.  It was incredibly frustrating until I read this post and was able to fix it.  Thanks, Willie!
