With XPression Designer 5.7 Build 3064 the current version for the CG System, we have upgraded the original PC hardware with more memory, SSD 500GB drive, a new Quadro M2000 video card and Blackmagic Decklink Duo2 I/O card. The system/software runs very well, with only one exception.
The Blackmagic Decklink Duo 2 is not recognised in the Hardware Input/Outputs dialog, but is available in the Audio Devices dialog. We are using RossLinq two channels to communicate and upload to the Ross Carbonite switcher buffer with no problems. The intention is to use the Decklink Duo2 to capture live video into Xpression as required. The Blackmagic software is version 10.8.3. Is this possible in the current configuration?
With thanks in advance.
