I have a car I need to animate as a wipe-on device. Straight forward, animate in X, rotate the wheels on Z, but I was wondering if there is a cool Visual Logic trick to get the X-position animation drive the z-rotation animation. In Cinema 4D's node-based scripting tool, XPresso, I would make what is called a set driven key for this, tying the relative value of Pos X to the Rot Z parameter of the other object, and teh result are wheels that rotate faster or slower depending on the the car's pos animation. However, I don't see a relative value node, only an absolute value node. I'm going to start playing with it now, but thought I would throw this out there in case there there is a way to make it work which I fail to stumble upon.
- Willie
