  • 1.  Renderview not updating in Sequencer
    Posted 03-06-2017 12:49
    I have a scene with a renderView which uses a camera I added to that same scene directed at some 3D logos. The camera and logos are placed so that you can't see it from the front view when you output. The renderView should show the logos on a normal quad in the front view. I've published visibility for the logos so I can use the correct logo at the correct time. When I output directly from Layout I can see the logos but from Sequencer you cant see anything...
    I've tried publishing the renderViews material and setting the correct material in the sequencer but no luck. I've also tried taking the renderView from a different scene. No matter what I do all the logos will only display when I change their visibility in layout.
    Any help here would be greatly appreciated.
    "‹v.6.5 b3600
    T
  • 2.  RE: Renderview not updating in Sequencer
    Posted 03-07-2017 16:36
    Can you post a sample project that has this issue?
  • 3.  RE: Renderview not updating in Sequencer
    Posted 03-08-2017 11:04
    Yes of course. As you can see in the project it works in layout, but toggling visibility of the ball in sequencer doesn't do much :-(
    https://fil.email/nqfzA
  • 4.  RE: Renderview not updating in Sequencer
    Posted 03-16-2017 18:30
    @garner Any luck?
  • 5.  RE: Renderview not updating in Sequencer
    Posted 03-20-2017 21:39
    Sorry Tobia. Will look at it ASAP
  • 6.  RE: Renderview not updating in Sequencer
    Posted 04-13-2017 20:08
    Hey Tobias,
    Unfortunately we can't replicate this issue, the logo is visible in layout and sequencer.
    Shoot me an email at gmillward@rossvideo.com and we'll arrange to get this replicated.
