  • 1.  VIDEO/ANIMATION NOT KEYING RIGHT
    Posted 08-03-2018 12:00
    When certain clips are imported into Xpression "clips" folder, they key properly. But after working with them in the designer, they do not key right when working with them.
    It's a heavy cloud looking key instead of the nice flash the original has.
  • 2.  RE: VIDEO/ANIMATION NOT KEYING RIGHT
    Posted 08-03-2018 12:47
    It was probably rendered as non-premultiplied (unshaped), and you would need to change that setting in the video shader in the material.
  • 3.  RE: VIDEO/ANIMATION NOT KEYING RIGHT
    Posted 08-07-2018 11:30
    This issue has been FIXED! Thanks so much!!
