The XPression API has a "GetDatalinqValue" function that can be used, though it will only work after an item has been focused, so you would need to focus it first. Optionally, you could GetSceneCopy from the TakeItem, and then retrieve the actual object inside of the Scene and can force a Scene-wide Datalinq refresh.
Zachary Fradette
United States
Sent: 05-10-2024 21:22
Subject: Change Take Item Name using script
Anyone ever figure out how to make this work when the "published text" is from a datalinq source? i have the script working but it only works with the published text that is static or static with a user control list.
Will Compton
Technical Director
NorthStar Church
Sent: 04-26-2018 14:58
I don't know if it's a bug that the string is not updated when we are using a datalinq bounding ...
