Hi Ilya,
No the ftp connection allows you to drop files onto the USB or do Single still only files directly to the Media Channels. This is the Ram Cache and is not internal storage.
Use the USB as the "storage" then use FTP to connect to the USB drive and then you can drag and drop file there which can then be loaded into Ram Cache by the operator.
BlackStorms Playlists are very good, further what is really neat is that you can have the Carbonite learn the playlist name for recall in the Custom Controls. Then you can modify the playlists on the fly in BlackStorm.
So example would be that I would learn 5 playlists example is Pack A, Pack B, Pack C etc... Now I would load those one at a time and then make a Custom Control to learn the names so that it can cue these packages. Then every show I can change the playlist contents to what is needed for each of the packages. Now the operator just hits the macro called Pack A when the Director want to roll Pack A. This way you can create "mini" playlists of clips and change them on the fly to what you need and roll them from the switcher!
