Steve,
Great tip with setting the "Play Range to 0 to 0/" Thanks!
Do you (or anyone else) know a way to auto-increment the "Name" field with Graphics that are sent to XPression from Ross Inception. Inception doesn't create a unique Name for graphics using the same template in the same story, so before exporting the graphic as a still image from XPression, we have to manually change the Name in XPression (i.e. adding "1, 2, 3, etc to the Name) in order for each graphic to be exported.
David Barnes
Prince George's Community Television
