  • 1.  Best Photoshop export settings
    Posted 01-03-2018 19:40
    Hi all -- have a big project coming up that will involve a lot of batch exports from Photoshop. These will be swapped in using Sequencer, and I wanted to see if anyone could confirm the best PNG settings. We've had some problems in the past with corrupted files and I'd like to prevent that this time.
    In Photoshop, under File -> Export -> Layers to Files, the options are PNG-8 and PNG-24. I have "Include ICC Profile" checked, and only "Transparency" checked under Options.
    Is there a best recommended setting if I'm using Export Layers to Files? Or maybe a script that handles it better than the default dialog?
  • 2.  RE: Best Photoshop export settings
    Posted 01-04-2018 03:34
    I usually just export out of Photoshop with the defaults for PNG. Never had a problem.
