Right... so I realize at the outset that I may not be able to provide enough information to get a cogent answer, but I have to try anyway...
I was just handed an XPression project file (actually made by the good folks at Ross) for a U-Bar element. The project is broken down into a lot of separate pieces, but my focus is on the 3 panels which span the lower third of the screen making the 'bottom' of the U.
Each of these panels are on separate layers, and I have been able to call them up in sequencer and see them, BUT when I look at the same scene in Layout, it's blank... no preview at all. There are of course NUMEROUS objects, and a 17 scene directors, each one with several 'script' tags scattered across their tracks, apart from the director designated as the 'preview' which is empty. I have tried evoking different directors and scrubbing to see if I could get something... anything really to appear, but no dice.
So is there anything generally speaking, to take into consideration when dealing with such a project? Obviously, I have to be able to see and interact with these things in layout mode if I am to affect any change. Any advice welcome.
Cheers
- Willie
